K.I.S.S. |
carlf
Topic: K.I.S.S.Posted: 28 februar 2007 at 16:03 |
carlf
Posted: 28 februar 2007 at 16:33 |
Æsj, ble dårlig bildekvalitet på bakgrunnen
Ser helt fin ut på orginalversjonen...
Henning L
Posted: 28 februar 2007 at 18:33 |
Du har undereksponert kraftig... prøv å overksponer en blender eller mer, lysmåleren er lurt av den lyse bakgrunnen.
Ta en serie med flere innstillinger. |
ØyvindS
Joined: 03 november 2004 Location: Denmark Status: Offline Points: 46 |
Posted: 01 mars 2007 at 09:22 |
Hei Carl-Fredric Kult å se at mj-ere også tør å eksperimentere med motivene. Fortsett med det. Sitat fra hjemmesiden til Bøe: "The way Nils Olav Bøe goes about making artworks is close to scenic arts; a lot of time is spent thinking about the concepts and how the pictures are to appear when complete. He selects the stage toys from model shops, most often objects from railway models in plastic, scaled 1:87. First he makes the scetches, the scenes are drawn, and when the stage has been set the pictures can be taken. The scene is given a background, and light is chosen to be as close to natural, out-door light as possible. Mirrors are used to reflect something of special importance, and mirrors are also used in a lamp posts that would appear too bright if fitted with light bulbs. The models are every-day objects like trees, houses, lamp poles, trucks; standing on what appear to be an endless surface. The effect is clinical, you watch the scene from a distance, as objects under the bright light in a laboratory. The scene becomes concentrated and everything is to be in full view. The focal point is very narrow, blurring "here" and "there". There are few objects in the picture, this is also to ensure that each one is revealed to a maximum. Bøe is turning the objects and the light to achieve the strongest result, and the stage is set through carefully adjusted lighting." Her er det litt å lære for mj-fotografen. De som har vært på mine mj-foto kurs vil antakelig huske at lyssetting var alfa og omega. Carl, du trenger å jobbe med lyset, og svarthvitt bildene dine er veldig grå. Og, du har plassert motivet på nesten nøyaktig samme sted i alle bildene. Dessuten, så skal det mye til at en helt monokrom grå bakgrunn gjør ting spennende. Kikk på bildene til Bøe igjen, og se at han også bruker bakgrunnen som en del av komposisjonen. Og, finn noe annet som underlag. Hvis du er ute etter å gjenskape realisme (som Bøe) så funker det dårlig med både skygge OG speiling av modellene. Svarthvitt foto er ikke enkelt. Med farger kan man ofte i søker"n se hva som funker (av farger mot hverandre). Det er værre i sorthvitt, hvor gråtonene helst skal funke (i hvertfall i denne type bilder). En liten 2-3 toms skjerm gir ikke det store overblikket. Stå på. Du er et friskt pust. |
mvh Øyvind Strøm
TomL
Joined: 02 november 2004 Location: Norway Status: Offline Points: 505 |
Posted: 01 mars 2007 at 14:03 |
Hei Carl-Frederic ! Et godt råd: "Hør" på rådene du får fra Øyvind. Han KAN det. Har opplevet det selv da jeg har tatt bilder. De gangene jeg har tatt meg tid, med lyssetting, komposisjon, stativ, og kritiske blikk, (lært av Øyvind på kurs..) så har resultatet blitt bra. Snarveier finnes ikke. (Men jeg prøver stadig likevel...har kjøpt ekstra blits Lykke til videre ! Fotohilsen Tom Lynga |
carlf
Posted: 01 mars 2007 at 17:11 |
Takk for råd, fint å få litt feedback.
Disse bildene var et lite eksperiment, der jeg tok det jeg hadde der og da. Jeg nappet pappen fra baksiden til en kalender og la den bøyd mot veggen, og satte noen origamisvaner på den først. Jeg endte med å plukke biler fra anlegget etterpå...
Cluet med disse bildene var egentlig å sette fokus på en ting. Derav den nøytrale bakgrunnen. Jeg skulle på dette tidspunkt til å spørre Øyvind hva han mente med speiling men ser nå hva du mener. Den pappen var visst ikke så matt som jeg hadde trodd
Jeg har et ganske dårlig kamera (tror jeg, billig greie, en Samsung Digimax A503). Blitzen har en tendens å være svært kraftig, og jeg har ikke funnet noen måte å dempe den på. Derfor er disse tatt uten blitz men på stativ. Jeg hadde en lampe ved siden av som gir et ganske kraftig, men fint og jenvt lys. Er det en annen måte jeg kan gjøre det på så det ser bedre ut? Ta bildene utendørs? |
ØyvindS
Posted: 01 mars 2007 at 20:44 |
Hei Carl-Fredric Du har tenkt veldig riktig. Og når du eksperimenterer finner du etterhvert hva som funker og ikke. Enten så ser du det selv, eller så ber du om feedback og får andres meninger. Av disse så forkaster du det som du selv ikke synes er relevant, og bruker resten. Du får plusspoeng for stativbruk. Det er hyperviktig ved modellopptak. For de som ikke har stativ, så kan det enkelt erstattes ved å sette kameraet på en stabel bøker eller CD"er. Poenget er å få kontroll over utsnittet og hendene fri. Mere plusspoeng for fosøk med papp og bøyd bakgrunn. Kjøp en matt grå A1 kartong i bokhandlen. Forresten, kjører du svarthvitt, så trenger du forsåvidt ikke bruke grå bakgrunn. Alle fargene gir jo en slags gråtone. Så det kan være ok å ha litt forskjellige bakgrunner for å ha noe som matcher gråtonene på objektene dine. Også plusspoeng for å koble ut blitsen på kameraet. Det blir skjelden bra med en kraftig lyskilde så nære objektivet. Glem alt om blits på kameraet. Du kan saktens få bra bilder med en vanlig lampe. Kraftig lys er ok, men ofte blir det finest å duse lyset med noe tykt kalkérpapir eller et laken. Reklamefotografer bruker store "lakner" (softboxer) foran lysene sine (de bruker oftest blitser, men prinsippet er det samme). Direkte, hardt lys gir ofte uønsket store kontraster. Men skal man illudere sollys, og bruke skyggene fra obektet, så dropp diffusoren. Utelys er topp, men direkte sol gir meget hardt lys. Lett overskyet kan bli veldig bra. Er det sol, så prøv lakenvarianten. Det gjør imidlertid at eksponeringstiden øker, og hvis du får med himmel og landskap kan det gi litt overeksponering av dette. Det kan man som regel justere i Photoshop. |
mvh Øyvind Strøm
carlf
Posted: 01 mars 2007 at 20:48 |
Okei, der er det noen ideer. Det blir nok ikke bare sorthvitt, farger kan også bli fint, spesielt med illustrasjonsbilder av tog, og ikke den litt spesi sort/hvitt varianten.
Jeg skal prøve å duse ned lyset, det har jeg ikke tenkt på. Takk for råd!
ØyvindS
Posted: 02 mars 2007 at 14:04 |
Hei igjen Carl-Fredric Siden du tydeligvis har sans for fotografering og vil lære mer, så kan du ha nytte av en serie med fotoleksjoner jeg laget til en Workshop om MJ-foto til MJF"s vårslepp i 2003. Det er mye tekst, men de som har giddet å lese det, og som følger prinsippene, har ihvertfall forbedret deres fotografering betraktlig, f.eks. Tom Lynga og bawaria (Terje). Du finner leksjonene på naboforumet: Fotoworkshop - mj-relatert fotografering - vårsleppet 2003 Innledning og Leksjon 1: http://www.norskmjforum.no/forum/topic.asp?TOPIC_ID=1418 Det finnes også en kommentar rundt teknikk og utstyr: Det finnes også litt om nærgrense, og veier rundt dette. Der er også noe tips om lyssetting. Leksjon 3: http://www.norskmjforum.no/forum/topic.asp?ARCHIVE=true& TOPIC_ID=1503 Leksjon 4: http://www.norskmjforum.no/forum/topic.asp?ARCHIVE=true& TOPIC_ID=1555 Leksjon 5: http://www.norskmjforum.no/forum/topic.asp?ARCHIVE=true& TOPIC_ID=1579 Endret: Rettet linker Edited by ØyvindS - 02 mars 2007 at 14:58 |
mvh Øyvind Strøm
carlf
Posted: 02 mars 2007 at 14:20 |
Ojojoj, mange takk. Her må jeg sette meg ned å lese litt
Men Leksjon 2 og 3 og det om nærgrense kommer ikke opp, jeg havner bare på frontsiden til NMJF istede
ØyvindS
Posted: 02 mars 2007 at 14:59 |
Hei Carl-Fredric Har sjekket alle linker og rettet i flere. Burde være ok nå. |
mvh Øyvind Strøm
