  New Posts New Posts RSS Feed - tog
tog
jan salvesen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jan salvesen Quote  Post ReplyReply Direct Link To This Post Topic: tog
    Posted: 21 august 2008 at 12:13
Hva hetter dette toget???
Hilsen Jan Salvesen
asai View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote asai Quote  Post ReplyReply Direct Link To This Post Posted: 21 august 2008 at 13:50
Det er vel et lokomotiv, ikke et tog........
Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote jan salvesen Quote  Post ReplyReply Direct Link To This Post Posted: 21 august 2008 at 14:53
Ok.
Hva hetter Lokomotivet???
Hilsen Jan Salvesen
Post Options Post Options   Thanks (0) Thanks(0)   Quote ses Quote  Post ReplyReply Direct Link To This Post Posted: 21 august 2008 at 18:24
Belgisk? 1950-talls-design?
jörgen edgar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jörgen edgar Quote  Post ReplyReply Direct Link To This Post Posted: 21 august 2008 at 20:33
Loket är SNCB/NMBS (Belgiska statsjärnvägarna) ellok typ 122, senare typ 22.
Byggd 1954 i 50 exemplar. Om jag inte missminner mej finns det fortfarande några ex kvar i drift :)
Mvh Jörgen Edgar
J Edgar
Post Options Post Options   Thanks (0) Thanks(0)   Quote jan salvesen Quote  Post ReplyReply Direct Link To This Post Posted: 16 oktober 2008 at 13:10
Hva hetter dette Lokomotivet?
Hilsen Jan Salvesen
Lars Gjertsen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars Gjertsen Quote  Post ReplyReply Direct Link To This Post Posted: 16 oktober 2008 at 17:48
Det later til å være et sveitsisk diesellok, type AM 842, bygget av MaK/Vossloh.
http://www.bahnbilder.de/name/galerie/kategorie/Schweiz~Dieselloks~Am+842.html
Det likner også veldig på lok DE103 som malmbanen i Kirkenes benytter, men helt sikker på at det er samme type fra MaK er jeg ikke.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eika Quote  Post ReplyReply Direct Link To This Post Posted: 16 oktober 2008 at 18:22
Hei Jan!
Jeg ser at bildene du viser ligger lastet opp på MjF sitt nettsted. Imidlertid kan det se ut som bildene er tatt av produsent og hentet fra produsenten eller en forhandlers nettside. I så fall har du strengt talt ikke lov til å kopiere og videreformidle bildene slik du gjør her med mindre du har innhentet tillatelse på forhånd. Personlig må jeg si at jeg ikke vurderer slikt "lån" av produsentens bilder for det største tyveriet siden produsentene normalt nok er glad for hver gang de kan få vist produktene sine. Likevel er jeg som moderator forpliktet til å påpeke reglene for degWink
Personlig lurer jeg mer på hvorfor du spør her om navn på lokomotivene dersom du har hentet bilder fra et annet nettsted. Det burde da stå en eller annen beskrivelse på det nettstedet, og man trenger ikke kunne utenlandsk for å gjette seg til hva som er typebetegnelsen på en modell vanligvis. Som regel er det nok å lete etter en "rar" rekke tall, bokstaver eller en kombinason av disse.
Hvor er det egentlig du henter bildene fra?
Jonas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonas Quote  Post ReplyReply Direct Link To This Post Posted: 16 oktober 2008 at 18:42
Hei Jan!
Kansje jeg tar feil, men hvis bildene hadde blitt tatt hos en eventuell produsent eller butikk osv, så skal det også stå der hva loket heter.
Og det er jo netopp dette han lurer på.
Klask meg på kinnet hvis jeg tar feilSmile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Svein_H Quote  Post ReplyReply Direct Link To This Post Posted: 16 oktober 2008 at 20:47
Hei Jan!
For meg ser det ut som et standard Märklin bilde hentet fra websidene deres, men siden det loket ikke kommer opp når jeg søker på diesellok har det muligens gått ut av produksjon, og da kan jeg ikke hjelpe til...
Det står hvertfall SBB CFF FFS der, hva som står i det hvite feltet klarer jeg ikke tolke...
Svein
Edited by Svein_A - 16 oktober 2008 at 21:09
Post Options Post Options   Thanks (0) Thanks(0)   Quote eika Quote  Post ReplyReply Direct Link To This Post Posted: 16 oktober 2008 at 22:36
Nei.. det er jo nettopp derfor jeg ikke forstår helt poenget med å kopiere bildene hit og spørre om hvilken type det er. For bildene er helt klart ikke av typen man har tatt hjemme på hobbyrommet av egne modeller, men av en type man normalt finner på butikksider hvor jo typebeskrivelsen allerede står...
Og det er dette jeg håper Jan kan oppklare for ossSmile
Post Options Post Options   Thanks (0) Thanks(0)   Quote jan salvesen Quote  Post ReplyReply Direct Link To This Post Posted: 17 oktober 2008 at 12:12
Hallo jeg tror var en privat side som jeg fant de to bilden dette er lenge sidden jeg fant disse bilden som er lakk ut her.
Jeg vett at dette er ikke lov til til og kopijere bider fra forhandlere uten og spøre først.
Jeg håpper at vi ikke blir uvenner på grunna dette.
Edited by jan salvesen - 17 oktober 2008 at 12:16
Hilsen Jan Salvesen
Arne Lie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Arne Lie Quote  Post ReplyReply Direct Link To This Post Posted: 17 oktober 2008 at 21:07
Hei Jan
Det er fint å se at du er så interessert i lokomotiver. Dersom du har lyst til å utforske typer og navn finnes det mange kataloger på nettet. Om du søker på Märklin, Trix, Roco, Piko vil du finne mye interessant. Om du har lyst til å se fotos av ordentlige lokomotiver finnes det masse i materielldatabasen på NJK sin hjemmeside eller hos Jernbane.net
Ikke bekymre deg for at noen er sure på deg. De er bare veldig skikkelige og passer på reglene på en ganske nøye måteLOL
Lykke til med jakten. Skulle du ha lyst til å spørre om noe mer synes jeg du skal komme med detSmile
Arne L
Arne L
This page was generated in 0,027 seconds.
