  New Posts New Posts RSS Feed - Kran
Kran
kokken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kokken Quote  Post ReplyReply Direct Link To This Post Topic: Kran
    Posted: 20 august 2015 at 21:39
Jeg skulle gjerne hatt tak i slike kraner, noen som vet hvor jeg kan få tak i dem??
Tom-Andrè Engebretsen
Post Options Post Options   Thanks (0) Thanks(0)   Quote b e pedersen Quote  Post ReplyReply Direct Link To This Post Posted: 20 august 2015 at 22:08
Den store ligner en del på Faller sin (eller omvendt Wink) ...
Post Options Post Options   Thanks (0) Thanks(0)   Quote kokken Quote  Post ReplyReply Direct Link To This Post Posted: 20 august 2015 at 22:23
Ja den gjør det. Mener Faller sin er kledd med trepanel
TeVe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TeVe Quote  Post ReplyReply Direct Link To This Post Posted: 20 august 2015 at 23:09
Tenkte Airfix/Dapol når jeg så den.
Link: kran
Terje V.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kokken Quote  Post ReplyReply Direct Link To This Post Posted: 20 august 2015 at 23:26
Den kan kanskje brukes, om ikke hele så ihvertfall "understellet"
MY1201 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MY1201 Quote  Post ReplyReply Direct Link To This Post Posted: 21 august 2015 at 00:15
Vil en styrenplate bote for trepanelet?
Post Options Post Options   Thanks (0) Thanks(0)   Quote kokken Quote  Post ReplyReply Direct Link To This Post Posted: 21 august 2015 at 07:05
Det vil noke gå bra, enten å kle styrenplaten utenpå eller sparkle over panel så det det blir seende ut som metallvegger
halvors View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote halvors Quote  Post ReplyReply Direct Link To This Post Posted: 21 august 2015 at 09:59
Og hva er feil med trepanel på veggene? Mange slike kraner, for eksempel de på havna i Arendal og malmkrana på Treungen hadde trepanel på kranhuset.
Steinar Snøtun View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steinar Snøtun Quote  Post ReplyReply Direct Link To This Post Posted: 21 august 2015 at 10:07
Som Halvor nevner så hadde mange av disse trepanel, og jeg mener mange av de gamle kranene på Oslo havn hadde rødmalt panel. Problemet med byggesettkranene kan være at de blir for store for ditt formål, kanskje hvis det finnes, en N-skala kran med noe ombygget hus kunne fungert.
Steinar
Bjørn R Larsen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bjørn R Larsen Quote  Post ReplyReply Direct Link To This Post Posted: 21 august 2015 at 10:50
Alle de eldre kranene på havna i Drammen hadde også trepanel.
http://bjornrl.wordpress.com
krsven View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote krsven Quote  Post ReplyReply Direct Link To This Post Posted: 21 august 2015 at 11:15
Og kranene hadde tre farger,en lys okergul - type, en mellomting mellom blå og lyseblå og rød som kanskje hadde litt "maroon" - preg. Kranene var plassert litt hulter til bulter og gav et fargerikt innslag til havnemiljøet. "Kølagrabbene" var røde - men felles for alle var nettopp trepanel. Kranene fra 1. verdenskrig ( Drammen Jernstøperi), med fast kranbom, løftet vel 1,5 tonn, mens de som var ombygd av Refsum på 50 - tallet og med bevegelig kranbom løftet noe mer. Alle er i dag hugget opp, de siste rundt 1995 - 1996 tror jeg.
krsven
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steinar Snøtun Quote  Post ReplyReply Direct Link To This Post Posted: 21 august 2015 at 12:42
Det står vel igjen en på Grønlikaia i Oslo som er pusset opp og skal tas vare på.
På digitalt museum dukker det opp noe hvis man søker på havnekran.
Steinar
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steinar Snøtun Quote  Post ReplyReply Direct Link To This Post Posted: 21 august 2015 at 12:47
Står tømmerkrana på Skulerud enda? Den burde jo være temmelig lik de på Rødberg.
Steinar
Post Options Post Options   Thanks (0) Thanks(0)   Quote kokken Quote  Post ReplyReply Direct Link To This Post Posted: 21 august 2015 at 18:53
N-skala kran blir ikke for smått?? Får se nærmere på N-skala kraner.
Edited by kokken - 21 august 2015 at 18:54
GETEL57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GETEL57 Quote  Post ReplyReply Direct Link To This Post Posted: 21 august 2015 at 23:03
Artitec sin H0 kraan 10.142 har trepanel og ligner, men har mye større understell for havnespor.
Her er lenke til en rekke ulike kraner:
Sjekk også Oslobilder.no. Et enkelt søk ga dette:
Oslobilder havnekran
Kraner H0
Terje
Post Options Post Options   Thanks (0) Thanks(0)   Quote kokken Quote  Post ReplyReply Direct Link To This Post Posted: 22 august 2015 at 12:04
Takk for linken
Post Options Post Options   Thanks (0) Thanks(0)   Quote kokken Quote  Post ReplyReply Direct Link To This Post Posted: 23 august 2015 at 19:46
Etter nærmere undersøkelser av gamle bilder så er selve kranhuset likt som tømmerkrana som stod på Skulerud stasjon.  Har også funnet en N-skala kran fra faller som jeg kan bruke som utgangspunkt, men selve understellet må alt scratchbygges. Her er et bilde av den på Skulerud.
Edited by kokken - 23 august 2015 at 19:47
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bjørn R Larsen Quote  Post ReplyReply Direct Link To This Post Posted: 23 august 2015 at 20:10
Denne kranen du viser på bildet har bevegelig utligger, mens kranen på bildet øverst i tråden ser ut til å ha fast arm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kokken Quote  Post ReplyReply Direct Link To This Post Posted: 23 august 2015 at 20:16
Det har du helt rett i Bjørn Runar, en liten glipp der Smile. Men dette er den kranen jeg har funnet som er nærmest mulig lik, den som stod på Rødberg.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Svein_H Quote  Post ReplyReply Direct Link To This Post Posted: 23 august 2015 at 20:17
Jeg var på Skulerud i 2010 og tok endel bilder av krana og understellet med tanke på scratchbygging, i tilfelle du ønsker å se de.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kokken Quote  Post ReplyReply Direct Link To This Post Posted: 23 august 2015 at 20:25
Du har PM
This page was generated in 0,187 seconds.
