  New Posts New Posts RSS Feed - høyere lyd
høyere lyd
Toy_Roller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toy_Roller Quote  Post ReplyReply Direct Link To This Post Topic: høyere lyd
    Posted: 16 desember 2007 at 23:17
har eit marklin damp lok
med lyd dekoder som sitter i tender...
men synest lyden er veldig lav...
er det noe å gjøre med dette??
borre noen huller i kullet????
Post Options Post Options   Thanks (0) Thanks(0)   Quote b e pedersen Quote  Post ReplyReply Direct Link To This Post Posted: 17 desember 2007 at 08:17
Jeg antar du har sjekket voluminnstillingen ....? Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toy_Roller Quote  Post ReplyReply Direct Link To This Post Posted: 30 desember 2007 at 02:46
nei hvordan???
er litt grønn på dette med digital!!
Espen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Espen Quote  Post ReplyReply Direct Link To This Post Posted: 30 desember 2007 at 11:53
Dersom du har MS (Mobile Station) som kjørekontroll og loket har en mfx dekoder(det står på esken til loket), så finner du hvordan dette ordnes i brukermanualen til MSen.
MVH Espen
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toy_Roller Quote  Post ReplyReply Direct Link To This Post Posted: 30 desember 2007 at 19:13
kjøpte lokket på ebay
MARKLIN HO 3082.30  BR 41 STEAM LOCO + TENDER
BR 41 out of Starter Pack 29625 - DIGITAL - SOUNDS.
Prototype:  In 1936 Schwartzkopff delivered the first class 41 fast freight locomotive.  It was quickly evident that this 1"D 1"h 2 (2-8-2) type locomotive was a multi-purpose locomotive by medium size trains.  The calss 41 locomotives had an output of 1900 horsepower and reached a maximum speed of 90 km/h.  The newly developed frame was paired with the class 03"s proven boiler design.  336 units were built from 1936 to 1941.  After 1945 approximately 220 units were left with the later German Federal Railroad where they were used to pull all types of trains.  The boiler pressure was reduced from 20 to 16 kp/sq cm to avoid boiler damage.  Since 1968 it has been designated the class 041.
Model:  BR 41 Locomotive Road Number 41 354. The locomotive has been retrofitted with 60901 High Efficiency Propulsion motor and ESU LokSound V 3.5 decoder with sound effects generator.  Locomotive operating sounds, smoke,  locomotive horn, bell,  and squealing breaks. Addresses that can be set (Control Unit) : 01 - 80 .   Address set : 41.    With the control unit / mobile / central station  F1 = smoke, F2 = Running gear lights,  F3 = Operating sounds, F4 = Whistle (f) Bell (r).  Headlights and smoke generator will work in conventional operation and can be digitally controlled.  The locomotive can be retrofitted with smoke generator 7226
The model is out of Starter Pack 296215, is in excellent condition and does not come with a box.
Length over buffers:  27.5 cm / 10 13/16 inches
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toy_Roller Quote  Post ReplyReply Direct Link To This Post Posted: 30 desember 2007 at 19:28
jeg fant jeg fant
Mute / Adjusting volume by function key
The LokSound V3.5 decoders offers a mute function.
You can enable the mute by pressing the F8 button.
For LokSound V3.5, you can also easily adjust the
volume during normal operation by the F8 function
button: Press the F8 button two times quickly in series.
Each time you do this, the volume is increased by one
step up to the max. After you have reached the
maximum volume, the volume is reset to the lowest
value again. You can toggle through 4 different
volume levels.
Clap flink å leite på nettet ivertfall !!! heheh
Edited by Toy_Roller - 30 desember 2007 at 19:31
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toy_Roller Quote  Post ReplyReply Direct Link To This Post Posted: 30 desember 2007 at 20:52
Men hvordan taster mann inn f8 på disse???
f også 8???
Edited by Toy_Roller - 31 desember 2007 at 04:04
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toy_Roller Quote  Post ReplyReply Direct Link To This Post Posted: 02 januar 2008 at 02:44
kan noen svare meg på hvordan man taster f8 to ganger ??
hadde blitt veldig glad for hjelp
godt nyttår til alle!!
Nils Gullhav View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nils Gullhav Quote  Post ReplyReply Direct Link To This Post Posted: 02 januar 2008 at 09:57
Før du kan få svar må vi vite hva slags sentral du har.
Og hva slag dekoder, evt varenr. på lokket.
Hilsen NilsSmile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toy_Roller Quote  Post ReplyReply Direct Link To This Post Posted: 03 januar 2008 at 00:34
alt jeg vet om loket er det som står i rødt oppom her..
ellers er det standar maklin digital kvite boksene?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nils Gullhav Quote  Post ReplyReply Direct Link To This Post Posted: 03 januar 2008 at 08:12
Du har da sannsynelig Centralcontroll 80f 6021
Med den er det svært begrenset hva du klarer å justere på dekoderen.
Alt etter hvordan montøren av dekoderen har stilt inn dekoderen gjør om du har tilgang til f5-8.
Normalt ligger den på adr. 255 hvis det er en MFx dekoder? Du kommer ikke over 80 med din sentral.
Er du heldig er den programert til adressen over den du kjører toget på.
Er det en vanlig LokSound ligger den alltid på adressen over, hvis han aktiverte den funktionen når det ble montert.
Ellers ligger det noen bruksanvisninger her: http://www.esu.eu/index.php?id=293
Hilsen Nils
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toy_Roller Quote  Post ReplyReply Direct Link To This Post Posted: 03 januar 2008 at 18:57
bruker 41 og 42
på 42 er der bjellle ei dame med #perong# stemme og fløyte.
vi har også noen sanne hand holdte kontroller! men husker ikke navnet på dei no.. kan ta noen bilder på mandag!
