  New Posts New Posts RSS Feed - Fleischmann og Roco
Fleischmann og Roco
BM65A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BM65A Quote  Post ReplyReply Direct Link To This Post Topic: Fleischmann og Roco
    Posted: 13 april 2009 at 13:07
T.o. så vil fremtidens digitalstyring være den samme for Fleischmann og Roco. Jeg viser til svar jeg har fått ved henvendelse til Fleischmann:
"...Fleischmann was taken over in 2008 by Modelleisenbahn, the company which owns Roco.
As a result, the Fleischmann Profi-Boss will be discontinued, and replaced by the Fleischmann controller which is exactly the same as the Roco multi-Maus.
You cannot use the Profi-Boss in conjunction with the Multi-Maus, but you can use two multi-maus controllers together."
ROBEL View Drop Down
MjF-styremedlem
MjF-styremedlem
Post Options Post Options   Thanks (0) Thanks(0)   Quote ROBEL Quote  Post ReplyReply Direct Link To This Post Posted: 13 april 2009 at 14:33
...som igjen er laget av LENZ digital :-)
