Fabrikkinnstilling
 Svar Svar
Forfatter
mikki Se rullemeny
Medlem siden: 19 august 2013
Land: Norge
Status: Utlogget
Innstillinger for innlegg Innstillinger for innlegg   Thanks (0) Thanks(0)   Sitér mikki Sitér  SvarSvar Direkte Link til dette innlegget Tråd: Fabrikkinnstilling
    Sendt: 27 januar 2018 kl. 13:16
Noen i dette fora som har satt en Digikeijs DR4018 tilbake til fabrikkinnstilling??
Til toppen
hamoell Se rullemeny
Medlem siden: 10 juni 2012
Land: Norge
Status: Utlogget
Innstillinger for innlegg Innstillinger for innlegg   Thanks (0) Thanks(0)   Sitér hamoell Sitér  SvarSvar Direkte Link til dette innlegget Sendt: 27 januar 2018 kl. 16:26
Reset the module to factory settings using POM programming Use this method to reset the module to factory settings using POM programming.
Step 1 : Connect the signal input on the decoder to the rails output on Your control unit. Step 2 : Ensure the module is receiving power via the module’s power input.   (You can also connect the power and signal inputs to each other) Step 3 : Set your control unit to POM programming mode.   (You can find more information about the POM mode in your control unit’s manual) Step 5 : Choose local address 9999 on your control unit. Step 6 : Press the button on the module until the LED goes on. Step 7 : Then program decimal value 8 in CV8. Step 8 : Press the button on the module until the LED goes out. Step 9 : It is important when carrying out a RESET that the module is now disconnected from the power.   Disconnect both the power and the signal inputs and wait for 3 to 5 seconds. Step 10: The decoder can now be reconnected to the power and will have returned to the factory settings.   BE CAREFUL! The decoder now has address 1 again
Min pusher: www.glm.no
Til toppen
mikki Se rullemeny
Land: Norge
Status: Utlogget
Innstillinger for innlegg Innstillinger for innlegg   Thanks (0) Thanks(0)   Sitér mikki Sitér  SvarSvar Direkte Link til dette innlegget Sendt: 28 januar 2018 kl. 08:29
Har du forsøkt dette selv. Jeg har prøvd dette flere ganger uten at det hjelper. Kobler du om ledninger på en annen måte enn når den ellers er i bruk. Begynner å lure på om min dekoder har fått en karamell den ikke tålte.
Til toppen
jhh61no Se rullemeny
Medlem siden: 05 november 2004
Land: Norway
Status: Utlogget
Innstillinger for innlegg Innstillinger for innlegg   Thanks (0) Thanks(0)   Sitér jhh61no Sitér  SvarSvar Direkte Link til dette innlegget Sendt: 29 januar 2018 kl. 07:50
Hei Mikki
Ikke fordi jeg ikke tror du har gjort det riktig 😜
Om du tar et bilde av modulen med alle tilkoblinger eller lager en skisse som tydelig viser dette er det ofte selv også lettere å se om det er gjort riktig.
I en del tilfeller viser det seg at mottaker av en melding tror han/hun har gjort som vedkommende har fått beskjed om men så er det en liten detalj som er forskjellig.
For Digikeijs interesserte vil jeg anbefale to FB grupper.
Tysktalende men stiller du spørsmål på engelsk så fikser de det også. https://m.facebook.com/groups/1151865658276152
Engelsktalende. https://m.facebook.com/groups/1346790392010051
Jarle H Hansen
Bergen
Til toppen
mikki Se rullemeny
Land: Norge
Status: Utlogget
Innstillinger for innlegg Innstillinger for innlegg   Thanks (0) Thanks(0)   Sitér mikki Sitér  SvarSvar Direkte Link til dette innlegget Sendt: 29 januar 2018 kl. 21:43
Jeg kan tydeligvis ikke gjort dette riktig, og har en mistanke om at dette beror på min bruk av Multimaus, eller rettere sagt mangel på bruk. Vil gjerne få lov til å komme tilbake på dette når jeg er hjemme igjen.
Til toppen
mikki Se rullemeny
Land: Norge
Status: Utlogget
Innstillinger for innlegg Innstillinger for innlegg   Thanks (0) Thanks(0)   Sitér mikki Sitér  SvarSvar Direkte Link til dette innlegget Sendt: 10 februar 2018 kl. 07:24
Mener jeg har fulgt anvisning fra produsent for tilbake stilling. Se foto. Rød og sort ledning går til skinnestrøm. Blå og brun går til ekstern strømkilde (en eldre blå Mærklin trafo). Problemer oppstod når jeg skulle koble på 2 penser til. Fikk da brukt feil dioder (Alt for kraftige 900 ohm). Dessuten er utgang 3 på dekoder mangelfull. Den mangler en skrue. Utgang 1 og 2 på dekoder fungerte fint inntil jeg gjorde denne feil. Nå reagerer den slik at uansett hvilken pens jeg ønsker reaksjon på så er det alltid den første som reagerer. Ellers har jeg en mistanke om at jeg ikke håndterer Multimaus riktig.4018
Til toppen
Land: Norway
Status: Utlogget
Innstillinger for innlegg Innstillinger for innlegg   Thanks (0) Thanks(0)   Sitér jhh61no Sitér  SvarSvar Direkte Link til dette innlegget Sendt: 10 februar 2018 kl. 08:00
Hei Mikki
Er dette oppkoblingen for reset ?
Du skriver diode men refererer til ohm (motstand)?
Kan du beskrive hva denne oppkopling skal utføre ?
Jarle H Hansen
Bergen
Til toppen
mikki Se rullemeny
Land: Norge
Status: Utlogget
Innstillinger for innlegg Innstillinger for innlegg   Thanks (0) Thanks(0)   Sitér mikki Sitér  SvarSvar Direkte Link til dette innlegget Sendt: 10 februar 2018 kl. 14:48
Beklager at jeg ikke er familiær med de nødvendige elektroniske faguttrykk. Som du ser på mitt foto har jeg lagt inn motstand til hver veksler, og det funker fint. Koblinger fra skinner/ekstern strømkilde er slik det var koblet når dette funket til å kjøre tortoise med. Har ikke koblet om for å endre til fabrikkinnstiller. Kun koblet fra Tortoise.  Slik jeg tolker anvisning for å gjøre dette er det ikke nødvendig. Hvis det er nødvendig så kanskje det er der feilen ligger?
Til toppen
 Svar Svar
  Del innlegg
Denne siden ble generert på 0,063 sekunder.
