  New Posts New Posts RSS Feed - 3Dprinting
3Dprinting
jhv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhv Quote  Post ReplyReply Direct Link To This Post Topic: 3Dprinting
    Posted: 09 august 2015 at 14:33
Til dere som kan 3Dprinting:
Er oppløsningen hos f.eks. Shapeways så god at det er formålstjenlig
å printe endestykker for motorvogn BM86/91 i H0 ?
Med endestykker mener jeg fronten med førerkupe, inngangsparti til og med
veggen mot kupeen.
GETEL57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GETEL57 Quote  Post ReplyReply Direct Link To This Post Posted: 09 august 2015 at 18:22
Her er ei lenke til en N-modell i 3D print. Detaljer etc ser bra ut, de har noen utfordringer med materiale synes det som i teksten
http://thenhrhtanewhavenrailroadforum.yuku.com/reply/57844/N-Scale-Models#.Vcd8SOQVi70
Terje
el18 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote el18 Quote  Post ReplyReply Direct Link To This Post Posted: 10 august 2015 at 06:21
Hovedproblemet er at du må slipe etter at du har fått delene og da er det mulig at du mister noe små detaljer. Ellers er det sikkert bra til H0 med FUD material.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Henning L Quote  Post ReplyReply Direct Link To This Post Posted: 10 august 2015 at 17:27
Nå er det vel "FED" – "Frosted Extreme Detail" som gjelder der i gården, for optimalt resultat.
"Frosted Ultra Detail and Frosted Extreme Detail are very similar materials, both printed using the same base resin and printer, but with different resolution settings. With 29 micron layers, Frosted Ultra Detail offers very high detail and is ideal for miniatures and figurines which will be finished and painted. With 16 micron layers, Frosted Extreme Detail offers the highest detail of any of the materials we offer and can be used for the most detailed miniatures, and models like molds and mold masters where very smooth surface finish is critical."
el18 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote el18 Quote  Post ReplyReply Direct Link To This Post Posted: 10 august 2015 at 18:45
Det lønner seg ikke å betale så mye mer for FED. FUD er i H0 mer en bra nok.
Loco View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Loco Quote  Post ReplyReply Direct Link To This Post Posted: 10 august 2015 at 18:53
Shapeways bruker forkortelsen FXD for Frosted Extreme Detail, ref. link FXD.
FXD er kun bedre enn FUD i z-retningen i 3D-printerene som Shapeways benytter (16 vs 29 μm). De to andre aksene (x- og y-aksene) har samme oppløsning for begge materialene. Problemet er at vi som brukere ikke kan velge hvilken orientering modellen vil bli printet i, det gjør Shapeways for å optimalisere/klemme inn så mange deler som mulig i et print slik at deres kostnad blir lavest mulig. FXD vil imidlertid være noe sterkere enn FUD.
Uansett om FUD eller FXD benyttes vil det sannsynligvis være behov for å pusse delene i noen områder. Der det er detaljer som mangler support (dvs. overheng i modellen i forhold til orientering av modellen i printeren) vil printeren benytte voks som support. De områder som supporteres av voks vil ikke bli like glatte som områder som er selvsupporterende, og må derfor pusses for å få glatte og fine overflater. Dette kan være et problem dersom områdene er små pga. mange detaljer.
Edited by Loco - 10 august 2015 at 18:56
- Loco -
jhv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhv Quote  Post ReplyReply Direct Link To This Post Posted: 20 august 2015 at 22:22
Beklager litt sen respons!
Har noen tilleggspørsmål:
Er FUD er "hardt/vanskelig" materiale å jobbe/finpusse med ?
Hvilke limtyper anbefales hvis flere deler skal forbindes ?
Går det an å kombinere FUD/andre plasttyper, evt FUD/messing ?
Hvordan tåler FUD varme, f.eks sollys ?
Loco View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Loco Quote  Post ReplyReply Direct Link To This Post Posted: 20 august 2015 at 22:43
FUD er et materiale som er veldig enkelt å pusse/slipe, men da må det også være mulig å komme til med verktøy eller sand-/smergelpapir. Materialet er sprøtt og brekkasje kan lett oppstå dersom veggtykkelser er for små i forhold til belastningene på delene. Det kan f.eks. være vanskelig å bore opp hull dersom veggtykkelsen er liten.
Limtyper som kan benyttes er hurtiglim (super glue) og epoxy lim. Det er en fordel å rubbe overflatene for å få bedre vedheft. Selv bruker jeg skrudde forhindelser for deler som belastes med litt krefter.
Kombinasjon med WSF går greit med lim og skrudde forbindelser. Jeg har ingen erfaring med FUD mot metaller, men vil tro at lim kan være vrient, kanskje hurtiglim vil fungere. Skrudde forbindelser vil sannsynligvis være det beste alternativet.
FUD er varmebestandig opp til 80°C. Det tåler ikke UV-stråler (dvs. sollys), og må derfor males for å beskyttes mot sollys.
- Loco -
jhv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhv Quote  Post ReplyReply Direct Link To This Post Posted: 20 august 2015 at 22:59
Tusen Takk for et nyttig svar; mot et evnetuellt nytt prosjekt.
This page was generated in 0.113 seconds.
